Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Contour
Engine Cooling
Water Pump
Replace/Remove
1998 Ford Contour Heat
1998 FORD CONTOUR
98,000 MILES • 4 CYL • FWD • AUTOMATIC
DISOKA
MEMBER
1 POST
FOLLOW
Changed the water pump and now there is no heat. The engine does heat up, not over heat. What could be the problem
Mar 15, 2010 at 6:46 PM
CERTIFIED EXPERT
Try bleeding it could be air in it don't work get it block and pressure tested
Mar 16, 2010 at 3:34 AM
