Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Contour
Fuel System
Fuel Pump
Relay
Location
Fuel Pump Relay Location ?
1998 FORD CONTOUR
RACHEL.WILLIS09
MEMBER
FOLLOW
Where is the fuel pump relay located?
Jun 4, 2009 at 11:02 AM
SQM
CERTIFIED EXPERT
The fuel pump relay is located in the fuse block under the hood.
I have attached the diagram (see below) for that fuse panel. It should be number K4.
You might find this article helpful:
https://youtu.be/Hlna_kUt7As
Thank you.
Jul 21, 2021 at 11:07 AM
