1998 Ford Contour Engine temperature rockets to red after 1
1998 FORD CONTOUR
109,000 MILES • 6 CYL • FWD • AUTOMATIC
BESTCATCH42
Engine temperature rises to red after thermostat and Radiator fluid flushed. When you run the interior fan the heat doesnt come out only cold.
Jan 13, 2009 at 6:09 PM
DAVE H
  • 13,384 POSTS
try bleeding the system .. sounds like it has air in the system from not being refilled correctly ..?
BLEEDING
WARNING:When engine is operating, DO NOT remove radiator cap under any conditions. Failure to follow instruction may damage cooling system or engine, or cause personal injury. Always wrap protective material around radiator cap to avoid injury from hot coolant.
COOLING SYSTEM
Turn heater controls to maximum and set air discharge to instrument panel vents. Turn blower to high. Fill cooling system with 50/50 mixture of coolant and water. Pause several minutes for circulation. Start engine and allow to idle. While engine is idling, feel for hot air at instrument panel vents. If air discharge remains cool and coolant temperature gauge does not move, coolant level is low.
Stop engine and allow it to cool. Top off coolant as necessary. Start engine and allow it to idle until normal operating temperature is reached. Hot air should discharge from instrument panel vents. Coolant temperature gauge should maintain a stable reading in middle of range. Upper radiator hose should feel hot to touch. Stop engine and allow it to cool. Top off coolant as necessary. Check for coolant leaks.
Some models are equipped with a coolant level indicator light on instrument panel. If coolant level indicator flashes an additional 1.0-1.5 qts. (.95-1.42L) of coolant mixture can be added to overflow bottle.
Jan 13, 2009 at 7:47 PM
