changed timing belt car was running rough and no power now the care is running great but still have check engine light with code p1381 ..when i did the timing belt and line up with the marks on the balance r and oil pain the car ran like garbage like it was running on 2 cylinders so i pulled number 1 plug and got TDC that way and locked the cams in and put the belt on know the car runs the best ever but still have check engine light and code p1381 which is the vct over advanced the book shows using a pin into the block to lock in the crank is this a must on this car and will this code come in if it is a tooth out on the timing belt
Jul 5, 2010 at 6:03 PM
