1998 Ford Contour Clutch will not fully disengage
1998 FORD CONTOUR
185,000 MILES • 6 CYL • FWD • MANUAL
BIGSCOOL
When I step on the clutch sometimes it will not fully disengage. the clutch its self dosn't seem to slip. What could cause this?
Aug 17, 2010 at 9:44 AM
WRENCHTECH
  • 20,761 POSTS
You have a hydraulic clutch system with a clutch master and slave cylinders. You likely have a leak in one of them and the fluid has gone dry causing it to draw air into the system. You will have to determine which one is leaking and replace it, then bleed the system. I recommend changing both at the same time because they usually fail close together.
Aug 17, 2010 at 10:10 AM
