1997 Ford Contour Odometer not working
1997 FORD CONTOUR
138,000 MILES • 4 CYL • FWD • AUTOMATIC
KALBOMAN
My 97 Contour I bought recently has a non working odomenter. The speedo works but the odometer and trip meter does not. This car has the analog odo, not the digital one.
Jan 29, 2009 at 3:28 PM
DAVE H
  • 13,384 POSTS
SPEEDOMETER/ODOMETER INOPERATIVE
Turn ignition switch to OFF position. Disconnect VSS connector. Remove instrument cluster. Check resistance of Blue/White wire between cluster connector C2, pin No. 6 and VSS harness connector. If resistance is 5 ohms or less, go to next step. If resistance is more than 5 ohms, repair circuit No. 8 (White/Blue wire) for open.
Measure resistance between cluster connector C1, pin No. 13 (Black wire) and ground. If resistance is 5 ohms or less, go to next step. If resistance is more than 5 ohms, repair open Black wire and retest operation.
Turn ignition switch to ON position. Check for voltage between cluster connector C1, pin No. 7 (Orange wire) and ground. If battery voltage is present, go to next step. If battery voltage is not present, repair open Orange wire and retest operation.
Turn ignition switch to OFF position. Check continuity between cluster connector C2, pin No. 6 (White/Blue wire) and center pin of speedometer printed circuit. If there is 5 ohms or less resistance, go to next step. If resistance is more than 5 ohms, replace printed circuit board and retest.Turn ignition switch to OFF position. Check resistance between cluster connector C1, pin No. 7 (Orange wire) and right head pin of speedometer printed circuit. If resistance is 5 ohms or less, go to next step. If resistance is more than 5 ohms, replace printed circuit board and retest system.
Check resistance from cluster connector C1, pin No. 13 (Black wire) and left pin of speedometer printed circuit. If resistance is 5 ohms or less, replace speedometer and retest system. If resistance is more than 5 ohms, replace printed circuit board and retest system.
Jan 29, 2009 at 5:19 PM
