1997 Ford Contour Heat
1997 FORD CONTOUR
HOLDEN
Heater problem
1997 Ford Contour 4 cyl Front Wheel Drive Automatic 130km miles
I have a 1997 Ford Contour. Problem is that when its cold i can run the car in idle for 25 minutes or so and i dont get heat till i step on the gas. When driving i have hot air but when im in drive and sit at a stop sign for a bit it starts to cool down and blows cool air. If i sit in park i have some heat but as soon as i put it in drive it blows cool. Just touch the gas a bit and i have heat. Replaced thermo with ford part, had it pressure tested and everything was fine but it still does it. Cant figure it out. Where can the problem be. Thanks
Jan 31, 2008 at 7:08 AM
HOLDEN
Heater core for sure.
Feb 19, 2008 at 7:35 AM
