1997 Ford Contour daytime runing lights
1997 FORD CONTOUR
ROVER15
Electrical problem
1997 Ford Contour Two Wheel Drive Automatic
hey i'm having problems getting my daytime running lights to stay off once i turn off the car right now i have the battery disconnected so it won't die on me .... the car has been sitting for 6 months and i just pulled it out and charged the battery had it running for a hour well i got it running but i need to know what to do about the day time running lights
Mar 15, 2009 at 2:34 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect a bad battery
and should have it checked ,tested or replaced
pull fuse #4
or pull DRL relay
or try and pull the E. brakes on
if you do one of the above lights should go out
Mar 16, 2009 at 7:52 PM
