1996 Ford Contour oil in spark plugs
1996 FORD CONTOUR
200 MILES • 4 CYL • 2WD • AUTOMATIC
ANGELINA510092
there is oil in spark plug chamber and is stalling out. have any ideas what could cause this?
Jul 24, 2010 at 9:36 PM
If the oil is on the outside of the engine around the pluge, chances are the valve cover is leaking. As far as the engine dieing on you, has the check engine light come on? When does it happen? Have you checked fuel pump pressure?
Aug 10, 2010 at 1:17 AM
