1996 Ford Contour need immediate help please
1996 FORD CONTOUR
KIMBERLYCAMPBELL
Engine Performance problem
1996 Ford Contour 4 cyl Front Wheel Drive Automatic
Car is acting like the speedometer sensor is bad and doesn't seem to b gettin gas when i push the pedal it has a new speedometer sensor/cable, egr sensor, massairflow sensor, and main computer fuse cause it blew
Aug 9, 2010 at 2:59 AM
EDWARD.S
  • 166 POSTS
Hi,If Car Has No Power ,It could Be a Few Things.One something Could be wrong with the trans,Check fluid first,and make sure it's filled to the mark. or could be a cat. converter going bad.But Before You spent anymore money on it,have the computer checked for codes, also i'd address the issue that the ECM fuse blew. that should not happen.get that looked at first,then have the codes checked.
Hope This Helps You,
Good Luck
Edward S.
Aug 9, 2010 at 5:17 AM
