1996 Ford Contour Horn Stopped Working
1996 FORD CONTOUR
16,000 MILES • 6 CYL • FWD • AUTOMATIC
TARTOP
Hello...
My Horn just stopped working, I checked fuse and horn relay both OK, horn works when I use the FOB to lock doors and it also works when I push the panic button on the FOB. Any suggestions would be greatly apreciated...
Thank You...
Jul 14, 2010 at 2:25 PM
Is there any noise that comes from it when you use it? has the Air Bag light come on?
Aug 10, 2010 at 1:29 AM
TARTOP
Thank you for the reply..
No noise at all, and airbag light does not come on...
Thank You..
Aug 10, 2010 at 6:03 AM
My guess is the "clock spring" in the steering wheel is bad. Usually, the air bag light will come on with it.
Aug 10, 2010 at 10:57 PM
TARTOP
OK than you for your suggestions/help...
-Hank
Aug 11, 2010 at 6:07 AM
Hank,
Let me know if it takes care of the problem.
Aug 11, 2010 at 9:14 PM
