i keep getting a trouble code of po171 which reads as system too lean. i have replaced the o2 sensor and cleaned the mass air flow sensor and ran sea foam through the fuel system along with octain booster and dry gas to absorb moisture.. the car had sat for a year without a gas cap and only a plastic bag to keep the tank clean. i have 2 days left to get the car through emissions and need to get it fixed asap.. do you have any suggestions as to what my next steps should be to correct this problem.. thanks
Jul 26, 2009 at 12:35 PM
