1996 Ford Contour car not recharging
1996 FORD CONTOUR
Electrical problem
1996 Ford Contour 4 cyl Two Wheel Drive
96 ford contour died. put new alternator and new battery. still will only run on battery charge. we tried 5 different alternators all new and been tested and test good. but it won't stay charged. what else could it be. help
May 19, 2008 at 3:14 PM
MERLIN2021
  • 17,250 POSTS
Check the battery cables at both ends, clean and tight! Then follow the positve cable to the solinoid, the smaller wires are the fusible links, test with a test light or volt meter, then check the cable from the alt to the power distribution box. In the box you will find a small black diode, it looks like a black fuse, check that for continuity in one direction only! thats the power diode.
May 19, 2008 at 3:17 PM
