1995 Ford Contour rough idle, dies under load
1995 FORD CONTOUR
126,000 MILES • 4 CYL • FWD • MANUAL
RODOH1973
  • 5 POSTS
The car has a rough idle and you can rev it up to the moon but when you release the clutch it acts like its running out of gas. when it warms COMPLETELY it runs FINE but still idles very roughly.It has new fuel filter,plugs wires,throttle position sensor and I got a MAP sensor from the wrecking yard, and have replaced or checked all vacuum lines. I don't have ready access to a scanner or volt meter.Any suggestions would come in handy as I am running out of hair and money.
Dec 31, 2008 at 10:04 PM
JAMES W.
  • 2,394 POSTS
Autozone and most major parts stores will scan your computer for free. Any stored codes in the ECM could really help narrow your problem down. My first thought is the ECM isn't adjusting the ignition timing to handle load. We could start guessing, but guessing can get expensive. Please advise.
Dec 31, 2008 at 10:42 PM
RODOH1973
  • 5 POSTS
Autozone only has a scanner for 1996 and up. I'll check Oreilly's Auto.
Dec 31, 2008 at 11:21 PM
JAMES W.
  • 2,394 POSTS
OK, let me know what you find.
Jan 2, 2009 at 11:03 AM
RODOH1973
  • 5 POSTS
The insulation had deteriated on the tempereture sensor and was shorting out, giving the wrong message to everything. Even the check engine light went out and it runs good cold! Still has a rough idle but I can live with that till later.
THANKS
Doug
Jan 9, 2009 at 9:38 PM
JAMES W.
  • 2,394 POSTS
Glad you found it. Thanks for the comeback.
Jan 9, 2009 at 11:24 PM
