1995 Ford Contour grinding
1995 FORD CONTOUR
210,000 MILES • 6 CYL • FWD • MANUAL
COPYTECH
I'm back!!! I have a problem when shifting 1/2 or 3/4 up or down, i get a grinding gear noise,but it does go in gear,and the gears are quiet! As suggested previously, I bleed the new clutch hydraulic system, and drained the tranny and put in fresh fluid ! ANY further sugestions most appreciated!! It drives me Nuts, and can't be great for the tranny! Also sometimes it works just fine but less often ,then it grinds
Oct 28, 2008 at 6:42 PM
IMPALASS
  • 3,112 POSTS
Hello
If I understand your problem correctly, there is a Technical Service Bulletin out on this though it specifically states 3rd it also talks about 2nd. I have attached it for your review.
Article No.
96-24-8
11/18/96
^ NOISE - "GRINDING" OR "CLASHING" HEARD WHEN SHIFTING INTO 3RD GEAR - VEHICLES WITH MTX-75 TRANSAXLE - VEHICLES BUILT THROUGH 9/1/96
^ TRANSAXLE - MTX-75 - "GRINDING" OR "CLASHING" NOISE HEARD WHEN SHIFTING INTO 3RD GEAR - VEHICLES BUILT THROUGH 9/1/96
^ TRANSAXLE - MTX-75 - HIGH EFFORT WHEN SHIFTING INTO 2ND GEAR - VEHICLES BUILT THROUGH 9/1/96
FORD:
1995-96 CONTOUR
LINCOLN-MERCURY:
1995-96 MYSTIQUE
This TSB article is being republished in its entirety to revise the service procedure and the parts required.
ISSUE:
A "grinding" or "clashing" noise may be heard from the transaxle when shifting into 3rd gear and/or a high shift effort may be required to engage cold transaxle on some vehicles. These may be due to a deflected lubrication condition causing early 3rd gear wear or high input shaft preload causing high shift effort.
ACTION:
Rebuild input shaft, changing the axial lash and installing a revised shift fork. These actions will prevent early 3rd gear wear and reduce preload to zero. Refer to the following Service Procedure for details.
Oct 28, 2008 at 6:55 PM
