1995 Ford Contour fuel problems
1995 FORD CONTOUR
235,800 MILES • 4 CYL • FWD • MANUAL
CONTOUR95
yeah my name is Patrick I had my brake line replaced as well as a fuel line that was replaced when I picked it up I had taken it on the highway and as soon as I went faster the car completely bogged down and went again like a jerking motion I replaced my fuel filter and it still does it the car starts up fine what else could it be you think it's bad fuel because they replaced that fuel line
Nov 3, 2010 at 12:39 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Nov 3, 2010 at 1:31 AM
