1995 Ford Contour Blower Motor Resistor
1995 FORD CONTOUR
LINZIE3219
1995 Ford Contour 4 cyl
How do i change the blower motor resistor on a 1995 ford contour. I have located the part but i cant seem to remove it. Thank you.
Feb 23, 2010 at 11:56 PM
DANAUTHIER
  • 156 POSTS
This is the best I can copy over from my data base, Hope it helpss. This is from the Ford service manaual. Of course, reverse to install new part, you will not need the flat blade screw driver to install, like you need to release the lock to remove.
1.Disconnect the negative battery cable.
2.Remove the push pins and remove the upper footwell panel from under the passenger side of the instrument panel.
3.Unplug the connector from the blower motor resistor assembly.
4.Insert a screwdriver approximately 0.2 inch (5mm) under the edge of the resistor assembly to disengage it from the evaporator housing.
5.Remove the resistor assembly.
If this does not help, let me know,
Thank you,
Dan
Feb 24, 2010 at 12:31 AM
