GEM module I need a schematic diagram for the module?
2008 FORD TRANSIT
196 MILES • 1.8L • 4 CYL • 2WD • MANUAL
HALIL KORKMAZ
  • 22 POSTS
Hello, I have a 2008 model Ford Tourneo Connect vehicle. I detected a short circuit on the GEM module motherboard with code 2T1T-15K600-CD because the door lock, alarm and remote control do not work. I need a schematic diagram about the module to repair it. I would be glad if you could help me.
May 10, 2025 at 2:37 PM
STEVE W.
  • 15,113 POSTS
If you are asking for board level schematics to replace parts, that is something we wouldn't have. For that you might want to ask Maic over at his site.
www.maicsalazardiagnostics.com
He does board level repairs and might be able to help.
May 10, 2025 at 5:31 PM
HALIL KORKMAZ
  • 22 POSTS
okay thanks.
May 10, 2025 at 5:54 PM
HALIL KORKMAZ
  • 22 POSTS
hello, i want you to give me the gem module pin output of my 2008 Ford Tourneo connect vehicle and the gem module diagram if available.
May 11, 2025 at 2:15 PM (Merged)
Why didn't you use the "Transit" option for your question instead of AA? Please repost in the correct forum.
HALIL KORKMAZ
  • 22 POSTS
okay.
HALIL KORKMAZ
  • 22 POSTS
hello i need 2T1T-15K600-CD gem module wiring diagram. my car remote control stopped working, interior lights do not work and when i open the door with the key the alarm beeps for 30 seconds, the fuse is good, what else should i check?
May 11, 2025 at 2:16 PM (Merged)
I would do a CAN scan to see if there are any codes for the GEM, here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here are the wiring diagrams needed to help see how the system works. Check out the images (below). Let us know how it goes.
May 12, 2025 at 8:52 AM
STEVE W.
  • 15,113 POSTS
The Transit Connect didn't come to the US until 2010 which is still the first-generation unit so these diagrams for a 2010 should be close to what you have. From the description it almost sounds like a bad GEM. What you might try is to disconnect the battery, wait 10 minutes and reconnect. See if the module resets. If not, then you will need a proper scan tool that you can use to test the system. Also use the manual key to lock and unlock the doors one at a time and see if anything changes.
May 12, 2025 at 2:54 PM
HALIL KORKMAZ
  • 22 POSTS
thank you so much, brothers.
May 12, 2025 at 3:39 PM
You are welcome, please use 2CarPros anytime we are here to help.
May 12, 2025 at 6:18 PM
HALIL KORKMAZ
  • 22 POSTS
perfect.
May 12, 2025 at 11:26 PM
HALIL KORKMAZ
  • 22 POSTS
Ford Transit Connect was produced only in my country, Türkiye, between 2002-2013. It was sent to America and every country. In fact, Ford Custom is currently produced only in Türkiye, but we get information about the car from you, America. The employees here do not give it, isn't it interesting? :)
May 12, 2025 at 11:56 PM
STEVE W.
  • 15,113 POSTS
Actually happens a lot. There are many places where you can buy vehicles but cannot get the service information on them unless you are a dealership. Some brands are worse than others though. I have friends in Japan and scattered across Europe and the UK and they are shocked that we have the amount of service information we have access to.
May 13, 2025 at 9:18 AM
HALIL KORKMAZ
  • 22 POSTS
Hello, I need the electrical wiring diagram for Ford Connect 2008. Can you help me please?
May 16, 2025 at 11:15 AM (Merged)
What one do you need?
May 16, 2025 at 11:16 AM
HALIL KORKMAZ
  • 22 POSTS
My 16-year-old car's remote control stopped working for the first time. I've been dealing with this for a week and the alarm goes off when I lock and unlock the car. I've changed the remote control battery 3 times and checked all the fuses, no problem. I think the problem is in the gem module, so I asked for a schematic. What else should I do? As far as I know, my car model doesn't have a receiver antenna. Am I wrong? What should I do?
May 16, 2025 at 10:34 PM
STEVE W.
  • 15,113 POSTS
It has an antenna. Plugs into the remote entry module. You need to go to the GEM and check the powers and grounds as shown in the earlier diagrams. If the powers and grounds are okay but the module isn't working correctly you get a new GEM and program it for your car. If you are looking for a board level schematic IE you are taking the module apart to repair the actual board, those are not available.
May 17, 2025 at 7:14 AM
HALIL KORKMAZ
  • 22 POSTS
If the module receiver antenna is intact, I will do what you say. Where is the receiver antenna of my vehicle? In the photo I sent in the attachment, it says that the gray cable coming out of the gem module is the antenna. I can't find where this gray cable goes, I want to see if the receiver is intact. Does this gray cable go to the remote entry module?
May 17, 2025 at 8:07 AM
STEVE W.
  • 15,113 POSTS
The antenna is inside the harness, not external. It runs from the module up toward the A-pillar.
May 17, 2025 at 1:03 PM
HALIL KORKMAZ
  • 22 POSTS
I can't find the remote control antenna. I need to check if it's good. If it's faulty, I can buy a new module for this one. Please show me where it is with a picture. 2008 ford connect gem module remote control receiver.
May 18, 2025 at 5:30 AM
STEVE W.
  • 15,113 POSTS
It is nothing but a grey wire that comes from terminal 16 and runs up through the harness to the front of the car. A simple test is to go to the module itself and try the remote right next to it. If it doesn't work the module is suspect because at that range the antenna isn't needed anyway. Plus, I doubt it is the antenna because it only increases the range you can get away from the vehicle.
May 18, 2025 at 5:57 PM
