2001 Ford Cobra Starting problems
2001 FORD COBRA
98,000 MILES • V8 • 2WD • MANUAL
IMBECILE
I am very frustrated. I have had my car to nothing
short of 9 shops, including 3 different ford garages
for diagnostics...no help at all. 3 years and counting.
The problem is that it sometimes does not fire up.
Sometimes. When I turn the ignition it doesn't catch,
for lack of a better term. Recently, I had the mass
air flow sensor replaced at a ford garage. 2 weeks later,
it started acting up again. I can get the car going if I
get on the gas immediately and put it in to gear, however
if it slips below 1000 rpms, the car shuts down. Sometimes
it will eventually begin to idle fine after about 3 minutes
of continuous driving. Some times it will never idle and
I go along restarting everytime I can't keep on the gas.
Other days it fires right up. It's more problematic after
it's been through wet weather.
Thank you for reading and any potential insight.
Feb 11, 2010 at 9:52 PM
HMAC300
  • 48,601 POSTS
if this has a security system i'd have that checked or try to get it disconnected and see if it cures the problem.
Mar 12, 2010 at 11:17 AM
