1998 Ford Cobra cylinder compression
1998 FORD COBRA
50,000 MILES • V8 • 2WD • MANUAL
SMROD71
I recently bought a used 1998 cobra mustang 4.6 dohc. The seler told me the engine was rebuilt. I would like to know what the compression test result should be for good cylinder compression, stock. Seller wasnt sure if the compression ration had been dropped or raised.
May 3, 2009 at 8:48 PM
HMAC300
  • 48,601 POSTS
you won't be able to tell compression ratio by a compression test. But if your compression is around 120-150 p.s.i. you should be ok. Make sure you do it correctly and there shouldn't be a 20% variance between cylinders.
Dec 17, 2009 at 7:04 PM
