I own a 1996 Ford full size Bronco, 5 liter 8 cylinder engine, manual 5 speed transmission, 4WD, mileage 122,000. The question is not repair oriented but use oriented. I have always been told to downshift the manual transmission to help slow the vehicle, either with or without brakes, in normal driving as well as 4WD conditions. I have been doing this for 35 years, as I have always had manual transmissions. I have never had a single transmission problem, nor any unusual clutch problems. Clutch replacement frequency is no higher than would be expected in any vehicle driven properly. Am I correct in using downshifting in this manner? Would this damage the transmission, or cause early wear (assuming the downshifting is being done correctly)? Thanks.
Aug 25, 2007 at 2:23 PM
