1st question my bronco will not move in reverse. It will go in gear and it tries to move but won't. you can put it in neutral and it still will not move. Put in drive and it will go forward. Is is the rear end or the transmission?
2nd question it will not go into 4 low. I changed the transfer case motor and I have checked the switch. It doesn't even try to go in. Every now and then when I put it in 4 high, it won't come out for a day or so and then it will go out and go back to working fine . Does that sound like a speed sensor problem?
Jan 23, 2006 at 5:53 PM
