1987 Ford Bronco, aboout 100,000 miles. Just had a remanufactured 4.9L long block put in my bronco. Now i have less power than before new engine. Shop that did the work said i had fuel problems so i replaced the in-tank fuel pump, the external fuel pump, the fuel filter, EGR valve, TPS sensor, Fuel Pressure regulator, ignition switch, MAP sensor. I still have NO power, cannot accelerate, when i hit gas i hear popping from throttle body area. Was told possible water in gas tank, 2 shops are unable to solve proble, PLEEEEEEZ help!!!!
May 19, 2006 at 7:36 PM
