Ford Bronco 2, 175,000 mi, 2.9L
1917 FORD BRONCO
NATE22
Hi, I'm pretty much car illiterate and am having trouble with this car. The bronco won't start. It clicks when you turn the key but that is all. The battery is brand new, and I also replaced the starter solenoid and the ignition switch. It will only start when I bridge the starter solenoid. Any ideas?
If anyone knows a approximate cost for having transmission seals replaced I'd also be really interested in knowing. Thank you.
Apr 11, 2007 at 8:10 PM
MERLIN2021
  • 17,250 POSTS
If the solinoid is good and the ignition switch is good, maybe you crossed the 2 small wires on the solinoid. Or a bad fusible link
Apr 12, 2007 at 2:26 PM
