1977 Ford Bronco 302 V8
Engine began to run rough during idle and throughout driving range.
I did all the obvious:
1. Changed the spark plugs and wires
2. New distributor cap
3. New fuel filter
4. Cleaned carb w/ cleaner
5. Made sure all hoses were connected
After all of the above were changed the engine continued to run the same as before.
Seems there is a slight knocking if you listen real hard. The bronco starts right up, seems to accelerate correctly. It is just rough with maybe a little lose of power. Kind of sounds like it is not timmed properly??? Is this something that would happen while driving???
Please help leed me in the right direction!!
3. New fuel filter
Aug 23, 2007 at 11:11 PM
