Distributor Gear Shear Pin
FORD BRONCO
MARKKN
I have a 1984 Fullsize Ford Bronco. I have had the distributor gear shear pin replaced twice. Following this I have had a new oil pump and distributor installed. The distributor gear pin sheared off again. What else do I need to check? What is causing the distributor shaft to bind? Is it possible that the new distributor was bad?
Nov 26, 2007 at 11:42 AM
Following this I have had a new oil pump and distributor installed. For what reason
This how things goes the camshaft drives the distributor drive gear in turn it drives the oil pump
Could be a bad new new distributor-
Nov 26, 2007 at 5:06 PM
