I have a 1988 Bronco II with 173,000 miles. Recently it started running rough and then stalling. If I let it go for a few hours or more, it starts but still runs rough. One day last week I got it to run for about an hour on some small errands but it died on me about a block from home. I replaced the ignition control module and a vacuum line on the fuel pressure regulator. I also checked that all plug wires were connected tight. What else should I do?? These trucks have 2 fuel pumps - 1 in-tank and 1 in-line. The in-line is the high-pressure pump. Do you think this is a fuel pump problem? What else could it be?
Jan 2, 2007 at 11:33 AM
