88 bronco idles high and check engine light is on
1988 FORD BRONCO
RONDAWGZ4
i have an 1988 ford bronco xlt with a 351 w engine mileage on the odometer is 216,000... but i have replaced entire drive train. Engine, transmission, 3rd radiator, steering box, 2nd rear end alternators, and starters and relays, and had a minor electrical problem fixed and i have also kept up with the regular maintnence. Ok now to my question lol. Truck started to idle high at around 13-1500 rpms, brought to a mechanic and told me the iacv was bad, replaced and still idles high, but this time at around 11-1300. Check engine light has now come on but goes off when it wants to. Please help if you guys can before i spend another fortune on this truck. thanks in advance Ronnie
Feb 7, 2007 at 9:35 PM
Vacuum leak? or The TPS-comeback when you have the code that triggered the CEL
Feb 8, 2007 at 1:33 AM
