85 Ford Bronco II 6.2 Liter Engine (transmission question)
1985 FORD BRONCO
CARLEENA
I have an 86 Ford Bronco II stuck in 3d gear but have a good tranny in my 85'. Will they inter-change ?
The 85 info is VIN # IMFCU14T8GUD42564
THE 86 info is Vin# IFMBU14S910009395
Aug 31, 2007 at 8:07 AM
ISLANDBRAD
are they both 2.9L EFI they will work together you may have to change over to the new tranys hydraulic cluch system easily done withought even disconecting the lines by removing the reservior & master cylinder from the pedal and firewall
and removing the bellhousing with it all
not to much work and no cluch bleeding
Oct 24, 2007 at 8:00 PM
