1996 Ford Bronco leaky oil pan
1996 FORD BRONCO
143,000 MILES • V8 • 4WD • AUTOMATIC
DICKY79
My bronco is going to serve as a cheap winter vehicle and I don't want to put a lot of money in, however I am willing to put some elbow grease into fixing it. It has a leaky oil pan/gasket, no obvious holes or rusting through. Any suggestions short of replacing the oil pan/gasket?
Oct 26, 2009 at 4:06 PM
Where is it leaking from? If it isn't the drain plug or rust holes, it most likely the gasket.
Nov 15, 2009 at 12:48 AM
