1996 Ford Bronco Engine change out from junk yard.
1996 FORD BRONCO
NELSONWILLIAMS
Engine problem
1996 Ford Bronco V8 Four Wheel Drive Automatic 300K + miles
I want to make sure the engine I purchase will bolt up with no modifications. Will a Cleveland and Windsor interchage? How do you tell the difference between the two? Per the VIN #'s the eight digit matches. Both are "H". My 1996 is a 5.8 which Vin said is 205 - 210 HP. The 1992 model I want to purchase shows 200 HP from it's Vin #.
Thanks,
Nelson Williams
[email protected]
Feb 10, 2008 at 12:54 PM
MERLIN2021
  • 17,250 POSTS
They use different sensors to input the PCM, one is pre OBD II the 96 Is OBD II so make sure you have the capability to put YOUR sensors on this motor!
Feb 10, 2008 at 2:44 PM
