check engine light o2 sensor codes
1996 FORD BRONCO
120,000 MILES • V8 • 4WD • AUTOMATIC
GAYLE5155
I was told the problem is probably the o2 sensor has gone bad. Could this be the problem? Is there more than one sensor in the converter for this year model Bronco? Thank you.
Jun 28, 2010 at 8:14 AM
SQM
  • 6,383 POSTS
What is the trouble code that you have?
https://youtu.be/DX--T1X_qfc
This vehicle can have up to 4 O2 sensors, depending on the emission standard.
Here is a helpful article:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
I have attached the location diagram as well as replacement procedure.
Let me know if you have any questions.
Thank you.
Jul 15, 2021 at 1:07 PM
