1996 Ford Bronco
1996 FORD BRONCO
155,000 MILES • V8 • 4WD • AUTOMATIC
BUCKHUNTER798
My 96 bronco is bucking(no pun intended) under exceleration. My friend said he had the same problem with his bronco and it was the pick up coil. Well, i changed that and that is not the problem. I noticed when i bought it that the fuel pump was really loud, now it is quiet. Any suggestions??
Sep 7, 2009 at 12:27 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Sep 7, 2009 at 1:28 AM
