1995 Ford Bronco Push button 4 wheel drive
1995 FORD BRONCO
113,000 MILES • V8 • 4WD • AUTOMATIC
DEMOE200
I recently tried to put my Bronco into four wheel drive by the push button method and it did not work. The 4x4 light or four low light did not come on when I pushed the button, nor did the automatic locking hubs not work. I attempted to manually lock the hubs and the four wheel drive did not work still. Is there a common reason for this to happen, or is my four wheel drive gone?
Thanks,
demoe200
Apr 14, 2008 at 5:45 PM
2CARPRO JACK
  • 11,533 POSTS
They have problems with the electric engagement motor on the transfer case. Test it for power at the switch and that power is going through the switch first . Then test it at the t-case motor
Apr 16, 2008 at 9:12 AM
