1995 Ford Bronco multiple problems all at once
1995 FORD BRONCO
135,000 MILES • V8 • 4WD • AUTOMATIC
DAVIDCADENHEAD
I have a 1995 Ford Bronco w/5.8 351. While driving the other day the ABS light came on, the O/D light started flashing and the speedometer stopped working. Went into limp home mode. I checked the fluid levels. I have replaced a fuse several times only to have it blow again. I replaced the speed sensor. What else could it be?
May 21, 2010 at 4:21 PM
WHat fuse are you replacing?
May 28, 2010 at 8:15 AM
DAVIDCADENHEAD
The # 5 fuse 15 amp in the Power Distribution box under the hood. It says it's for ABS and a number of other things.
Jun 5, 2010 at 10:44 AM
