1995 Ford Bronco BANGING SOUND FROM REVERSE
1995 FORD BRONCO
130,000 MILES • V8 • 4WD • AUTOMATIC
MGERSH7
  • 6 POSTS
My bronco makes a banging sound when taken out of park. Sometimes during take off under normal conditions will get a banging sound from trans. Happens while hot or cold out . Was told that could be torque converter, also was input shaft. Was also told was front pump was going bad. Trans shift fine all the time. Just happens during described times. Visually inspected saw nothing damaged. thanks for the help.
Dec 7, 2007 at 10:23 AM
JWALTH02
  • 180 POSTS
Is the bang combined with a jerk? Check your U-Joints on your driveshaft and make sure all the bolts are tightened. It's probably time for new U-Joints.
Dec 7, 2007 at 5:12 PM
Yep, I agree with that, these trucks have a tendency to go through U joints. Here are two guides that can help us see what's going on:
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
and
https://www.2carpros.com/articles/how-to-replace-a-universal-u-joint
Please go over these guides and get back to us.
Jul 13, 2024 at 2:13 PM
