My ford bronco has gotten its tranmission replaced with a rebuilt one. Sometime after that the speedometer started wavering and then the bronco began to stall when coming to a stop sometimes.
This has happened before and it was a ground that was the problem. This time the ground is fine, the speed sensor has been replaced to no avail.
The Transmission also shifts at the wrong points and at 35mph switches back and forth and cant make up its mind.
A small thing i noticed is that after starting when i push the tripometer button the speedo dips and the readout of the mileage flashes and then i have to press it again to get the trip.
Any help would be greatly appreciated.
May 20, 2008 at 10:51 PM
