1994 Ford Bronco Will not crank
1994 FORD BRONCO
164,000 MILES • V8 • 4WD • AUTOMATIC
SJPOPI
I started up my Bronco no problem. I stop at the store and can back and it would not start. I tried to jumping it nothing.
Lights, horn, radio all work when I turn the key you hear all the electrical as normal. Then you go to start it and not a sound, no clicking as if it dead. I have turn with the light on they do not dim. I’m puzzled…
Jan 7, 2009 at 6:43 PM
BILLYMAC
  • 2,204 POSTS
there is a solinoid on the passengers fender the battery cable connects to one side the oppisite side connects to the starter cable.there will be one or two small post on the front of the sol run a wire from the pos post on the batt.to the post on the sol if the truck cranks sol is ok check wire that plugs to that post use test light hold key on crank position light should light up ..hope this helps billymac
Jan 11, 2009 at 9:56 PM
