1994 Ford Bronco check engine light
1994 FORD BRONCO
95,500 MILES • V8 • 4WD • AUTOMATIC
BONO BRONCO
  • 18 POSTS
2 weeks ago when it was really cold like 18 degrees the check engine light came on for about 3 miles and shut off and didnt come back on till next day and did same thing then today it wasnt that cold and it came on for about 5 miles and shut off what can be the problem? my fluid levels are good thank you so much i really appreciate it.
Feb 12, 2008 at 6:57 AM
You need to have the OBD2 code/s pulled at Autozone and comeback with the code/s so we can start the diagnosis
Feb 15, 2008 at 12:13 AM
BONO BRONCO
  • 18 POSTS
autozone set they didnt have a tester for the bronco because it is an obd I so i went to advance and bought an obd I and the code came back anout the egr valve and throttle position sensor too high voltage so what can this mean? i thank everyone that can help
Feb 21, 2008 at 10:46 PM
