1994 Ford Bronco Alternator
1994 FORD BRONCO
150,000 MILES • V8 • 4WD • AUTOMATIC
HERNANDEZBR
My vehicle has 150K miles on the same alternator. I believe the bearings are going out. Should I replace the whole alternator or just the bearings?
Another question: Same vehicle. My (original) starter solenoid is periodically not engaging. Should I replace the solenoid or the whole starter?
thx.
Sep 21, 2008 at 9:06 AM
MERLIN2021
  • 17,250 POSTS
The solenoid is on the inner fender, next to the battery, so I would replace only the solenoid. Unless you can remove the pulley and have done an alternator or two, get the new alternator. If you choose to rebuild it yourself, get a new brush set too.
Sep 21, 2008 at 9:11 AM
