ok heres a little history, truck was running great but the check engine light is on, well it snowed alot so for the first time since i owned the truck i put it in neutral and shifted into 4h, now i diddnt go over 30-35 and only drove from where i engaged it to my home 4 miles away, at that point i parked it, put it in neutral and shifted the auto tranny to neutral ,the four wheel drive to neutral, everything as far as i know seems fine up to here. i went to put it into park from neutral and i felt and heard a grind so i stopped quickly and put it back into neutral went through the entire range of 4x4 2h ,4h , neutral, then low, back to neutral, then it diddnt grind when i shifted into park, but to double check everything was ok i shifted into drive and it is if i was in neutral in all gears, so im stuck in four wheel drive. any comments or suggestions on what my problem might be will be greatly appreciated.
Jan 6, 2009 at 1:26 PM
