1993 Ford Bronco the TPS
1993 FORD BRONCO
19,600 MILES • V8 • 4WD • AUTOMATIC
STRYKERSDADDY
do i need to remove the throttle body to remove this.
Dec 20, 2007 at 7:18 PM
BLACKOP555
  • 10,386 POSTS
You do not have to but it sure makes it easier to reach and work with, also easier to mark and view the marks you make.
Dec 20, 2007 at 7:37 PM
CFBRONCO19
  • 15 POSTS
yes you definitely have to remove the throttle body to remove the tps since the fact that it is located beneath the throttle body. luckily the throttle body is easy to take off, just remove the coolant lines from it and remove the four bolts, i think their 7/16 if im not mistaken. once you have the throttle body remove theres going to be two phillip screws that hold the tps in place. make sure when you put the new tps that the ohms of the tps should be at anywhere between 0.90 to 1.00 ohms closed
Feb 16, 2008 at 7:31 PM
BLACKOP555
  • 10,386 POSTS
little bit late on that post, 2 months. i answered his question and you do not have to ive done it before.
Feb 16, 2008 at 8:28 PM
