1993 Ford Bronco Oil pressure gauge
1993 FORD BRONCO
133,371 MILES • V8 • 4WD • AUTOMATIC
BP1110
Once my engine warms up my oil pressure gauge flutters on almost zero pressure when at idle speed. But once I accelerate the pressure returns to normal immediatly and then returns to low when I slow down. Also if I shift into neutral or park the gauge quickly returns to normal. Any suggestions on what the problem is would be greatly appreciated.
Feb 6, 2010 at 8:43 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
First thing to do is have the engine oil pressure tested with a mechanical gauge, this will give us the actual readings, this may just be a faulty sender or dash gauge, post the readings here, cold idle, hot idle & hot 2000 RPM.
Mark (mhpautos)
Feb 6, 2010 at 8:47 PM
If the engine is not making any type of knocking noises upper/lower end of the engine-I wilkl start by replacing the oil pressure switch
Feb 6, 2010 at 8:48 PM
BSTUBBS2
[quote:dade1ecff8="rasmataz"]If the engine is not making any type of knocking noises upper/lower end of the engine-I wilkl start by replacing the oil pressure switch[/quote:dade1ecff8]
and what if your engine is making a knocking noise at lower end of engine ?
Feb 17, 2010 at 8:25 PM
MHPAUTOS
  • 31,937 POSTS
If your engine is knocking, this will be the crank bearings destroying themselves with no oil pressure.
Mark (mhpautos)
Feb 18, 2010 at 4:42 AM
