1993 Ford Bronco no heat
1993 FORD BRONCO
193,000 MILES • V8 • 4WD • AUTOMATIC
CLEARLAKEJERRY
all air functions including blower work as new but it will not blow heat. Hve trouble shot all I can think of-any help?
Jan 2, 2010 at 9:10 AM
BIGJIM79
  • 239 POSTS
does the engine heat up like normal?
Jan 3, 2010 at 10:16 PM
JERM240
i had the same problem and ironically found it by not looking for it there is a vacuum line that runs to the passanger side of the truck up by the radiator mit and weather check and leaking badly replaced it and boom my heat was back come to find out ford ran a vacuum control valve out the intack you can follow one of your heater core lines back and find it it you have a vacuum leak its not opening the vavle. giving you little or no heat! just somthing to look for!
Jan 5, 2010 at 5:38 PM
