1993 Ford Bronco Need some answers
1993 FORD BRONCO
175,000 MILES • V8 • 4WD • AUTOMATIC
93 FORD BRONCO
1993 Ford Bronco Just installed new ford fuel pump and filter 2 months ago and has worked great till today. After 15 min to a hr. of running it will just die. Fuel pres. goes to 0 Let sit for awhile and it starts again 4o psi while running. When it dies u can't hear fuel pump turning on. Seems like relay (fuel) clicks once. When u can hear pump it starts. HELP
Apr 16, 2009 at 11:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I suggest swapping out fuel pump relay with a known good relay. Let me know if that solves the problem..
Thanks for using 2CarPros.com!
Apr 17, 2009 at 2:39 AM
93 FORD BRONCO
I replaced the fuel pump relay this morning and low and behold it died again after about and hr after running
Apr 17, 2009 at 7:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay..is there any anti-theft devices on your vehicle?
Inspect the wiring harness connectors to the fuel pump as well as the relay.
Apr 17, 2009 at 8:09 PM
93 FORD BRONCO
No there is no theft alarm that I am aware of. At least since 2004 that I know of. I did recheck wiring harness to the fuel pump. Jiggled wiring harness while running, no change. I'm wandering if module of some sort???
Apr 18, 2009 at 3:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
a temp sensor could cause the problem, but usually the vehicle will run,just very poorly...
Apr 18, 2009 at 2:40 PM
