1993 Ford Bronco My temp gauge always says cold.
1993 FORD BRONCO
170,000 MILES • V8 • 4WD • AUTOMATIC
CUTTYBUDDY1969
  • 4 POSTS
I think the thermostat isn't working or broken. The temp guage works ,but it is always stays cold. When I start my car after it sits for a a few hours it idles high for about 5-6 minutes before it goes back down to 1,000 rpm.
Jan 22, 2010 at 6:44 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect an open thermostat
remove and check
Jan 22, 2010 at 6:51 PM
If I were you just replace the thermostat, also check and test the engine coolant temperature sensor.
High idle problems: Try cleaning out the idle air control valve
Jan 22, 2010 at 6:53 PM
