Vacuum hose routing
1993 FORD BRONCO
OFFROADJUNKIE
Can I get the engine vacuum line routing?
Nov 13, 2009 at 8:48 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/188069_93broncoemission_1.jpg
Nov 13, 2009 at 9:38 PM
DADSF350
had fir and melted
Dec 29, 2020 at 1:55 PM (Merged)
HMAC300
  • 48,601 POSTS
there are 2 different ones i'm sending both. make sure to read this index. yours is only figure 4&5, figure 5 second drawing.
WOLFGON
i have a bronco 2.it wont run with all of its vacuum hoses hook up.i can take the pvc hose or the brake hose off and it will run.
That tells me there is no air getting to the engine. Have you checked intake for blockage of air, air filter, induction tube... Also, check to make sure the IAC is allowing air to enter the engine.
OWENSBIGHEART
Have a 85 Bronco II 6 cyl 2.8l and I have the manuel but can not see where all the vacuum lines go. Fixing it up but there is line off and can not find where it goes. Can anyone help me please?!?!?!?!
BIGJIM79
  • 239 POSTS
where does it look like it comes from?
OWENSBIGHEART
Well come to find out the persosn who we bought the bronco from. Disconnected all the vacuum hoses. Trying to find out which one goes where by the manual. It doesnt show it very good at all.
BIGJIM79
  • 239 POSTS
I would go to the dealer ship and get a print out from one of their because I have looked and cant find a decent image anywhere. I hope this helps.
OWENSBIGHEART
Thanks, at this point anything helps. I never knew they would do that for you. We looked at alot of images and your right not very clear. Thanks again
BIGJIM79
  • 239 POSTS
no problem. Glad to help
