1992 Ford Bronco WILL TURN OVER BUT WONT START
1992 FORD BRONCO
212,156 MILES • V8 • 4WD • AUTOMATIC
SCREWY61
1992 BRONCO WITH A 5.8 WILL TURN OVER BUT WONT START.LAST TIME I DROVE IT IT RAN OK BUT WHEN TRYING TO ACCELERATE IT SEEM TO SPUTTER AND I HAD TO BACK OFF THROTLE
Sep 6, 2010 at 7:40 AM
Do below to determine if its fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 6, 2010 at 7:42 AM
