i have a 1992 ford bronco 302 5.0l v8 with 202000 miles, i was having a problem with the engine that it would lope at idle or idle erratically. when i would start the engine up in the morning it would warm up fast idle at 1400rpms for about 10 seconds then it would come down to about 700rpms, it would then start loping on idle from 800rpms to 500rpms then back up to 1100rpms then back down to 500rpms. after about two minutes the loping would go away and idle fine after the engine would warm up. i decided since the engine had alot of miles and the valves were burned i did a top end overhaul, sent the heads out to the machine shop to have them replace the valves and re-deck the heads. i also replaced all the gaskets, vacuum lines, egr valve & sensor, coolant temp. sensor, o2 sensor, fuel pump, and full tune-up. unfortunately after everything i did, it still idles erratically. i do notice that the engine is running really rich when it does the loping on idle, small puffs of black smoke would come out of the exhaust. the only thing i haven't replaced yet that i think may be causing this problem would be a bad m.a.p. sensor or fuel pump regulator. i did check compression and its perfect, also checked vacuum and its vacuuming at 17hg in lbs which is perfect according to vacuum specs on the owners manual. can you suggest something that might be bad that is causing this problem? if so let me know. thanks
chris
chris
Feb 14, 2008 at 7:10 PM
