1992 Ford Bronco engine harness
1992 FORD BRONCO
200,000 MILES • V8 • 4WD • AUTOMATIC
JOSH SAMMONS
My bronco has anti lock brakes and I have a harrness that Dosent have anti lock brakes. If I installed it would the brakes still work, minus the anti lock?
Jan 8, 2010 at 3:11 PM
CH112063
  • 1,320 POSTS
No they will not. If you want to change the wiring the ABS must go. You need to instalol standard power assist braking system. You could look for a sub-harness that may plug in, by calling a Ford parts dealer. Each harness has a part number.
Jan 9, 2010 at 2:10 PM
